Originally Posted by
phakur
Andy-
My question above was on using a single 2300 LIFE with a 30 cc yak.
Just for info--I have regular voltage high torque digital servos all around.
I suspect that the ignition probably uses around 200 or so mah per flight
What do you think I could expect for a reasonable flight time and number of flights before recharging this single battery?
Thanks-
Larry
On that setup on a 50cc with a 2300 I was charging every 3 flights (10 to 12 minutes), it would report the battery at 50% capacity when I plugged it in. A few times I would do 4 flights and it would be in the 40 percent range.
Probably could have done more but as fast as they charge, why bother right?
