RCU Forums - View Single Post - Receiver& ignition on same batter
Old 11-20-2013 | 09:49 AM
  #50
rexbirk
Originally Posted by phakur
Guys-
I am interested in a single battery in a 30cc Yak I am putting together with a DLE 30 (new HV ignition).
I have three 30cc planes and all have the IBEC Unit and a single 2300 mah A123 pack. If I fly 6 flights I generally have to put back in 800 to 1000 mah . The actual usage is less since the charger is less than 100% efficient.
Any thoughts on battery size? I will be using LIFEs.
I was planning on using two by 2300 but that may be overkill.
Larry
I have three 30cc planes and all have a single A123 6.6 volt of 2300 mah and an Ibec Unit. After 6 flights I generally have to put 800 to 1000 mah back in the battery. Since the charger is less than 100% efficient the actual usage in less. My rule of thumb is to use no more than half the battery's capacity before charging. One 2300 is fine in a 30cc plane.
