RCU Forums - View Single Post - Engine for AW yak 120
Thread
11-20-2013 | 11:08 AM
4
Aero-Works
Mar 2006
685
Aurora, CO
Ameyam,
Because it is a Yak with a round cowl it is OK and typical for the engine to stand off more then normal. Also, you can use slightly shorter length stand offs and let the carburetor set inside the firewall a little and you can move the cowl out slightly by making the holes in the cowling longer.
The overall weight of the plane will be higher but you can reduce weight with battery selection, smaller fuel tank “Gas gets much better fuel economy then Glow” and using Carbon Fiber accessories.
If you are looking for an all out 3D plane that was designed around the 30cc-35cc class engine have you seen our 30cc Freestyle 260 model? Visit:
http://aero-works.net/store/detail.aspx?ID=518
Let me know if you have any more questions
Thank You
Rocco
Like
Aero-Works
View Public Profile
Send a private message to Aero-Works
Find More Posts by Aero-Works
View iTrader Profile
