A little correction. I was messing with my radio and realized I had set two throttle curves, one at full and one limiting the tip end for when I use the 25x10 prop. So when I did the run-up test with the 26x10 I was only getting 5600 rpms. so next time I will go will try both mixes. Man there is a lot to remember with this bird. It will have a very evolved pre flight routine I need to start training with.
TB
