I use the heat gun whenever I make a mistake, {OK, Once} and then you are able to re-use the part too. If you get a lot of back up heat blast back into the heat gun it will also burn it out. How would I ever know that??
Originally Posted by
countilaw
Dissolve, no way. But you can heat epoxy with a heat gun and try to peel the softened epoxy from the area.
Frank
