RCU Forums - View Single Post - Instructor to beginner again
Old 11-25-2013 | 05:02 AM
JohnBuckner's Avatar
JohnBuckner
Hey HP was hopeing you would come on board this thread. What I ment about a mode assignment was not any change in the the stick or rudder on the stick I was just wondering if any had ever called single stick itself a mode. I don,t think so but just curious.
The Aristo Cat I added ailerons according to plan but I did add two little servos in underwing surface mounts. I also used the plans dihedral recommended in the plans but that indeed is a bit much and the airplane flys nicer as you said with just rudder. The plans ailerons are very skinny and not much chord,.
If the 'Kid' I mentioned is successful in the implant of the Hitec 2.4 components in my Futaba 9channel single stick (well, it will just be a shell and gimbels of the futaba) I am building up a Goldberg Sailplane for it.
John
Name:	2.4 single stick Futaba.JPG
