RCU Forums - View Single Post - The new JR Venture
Old 05-03-2002 | 01:47 PM
  #37
bigwave
Default Venture has arrived
I just received my JR Venture from Heliproz. It'll be tonight before I get to tear into it. Since I've only been flying Helis for 9mo I'm not sure what my opinion will be worth. So far I've built and flown a Nexus Legato, Standard Nexus, and I'm currently flying a JR Ergo 46. I will leave it setup in the " mellow " mode for now until I get a little better. I'm going to use a Hitec/RCD Eclips 7 radio in it with Hitec 615 and 425bb servos. I'm going to start off using the 425bb on the CCPM but I may switch to the 525bb's if they don't seem quick enough. I've also read all the post at runryder so I'm going to check everything before I even begin assembly. I'm fairly new at Heli's but I'm a stickler for perfection and details so I'm sure I'll end up tearing it all apart and checking the bearings, bearing holders ( for burs that may cause a bearing to sit untrue in the holder ), etc. If the weather holds out I may get her ( I still call my ships her ) in the air Sunday.
Whooooo-Hoooooo
