BigWave
BigWave,
On your swashplate mixing menu you should have both the ail and elev numbers (+)positive and the pitch(-). If not then reverse the servos to that this is your result.
I have the JR 8103 and this is what they showed in the manual.
Flew a gallon through the little V30 this weekend at the MayDay event. I can say that this is one sweeeet little bird!!! It is VERY smooth and stable. I have the 3D setup except for the shorter flybar and 3D paddles. It is very lively with 0 expo yet still very gentle in a hover. If one were to leave it with the basic setup and the weights in the paddles then it would have to win the prize as the best beginner heli. I am still very impressed with how stable it is in the wind. JR has a well designed copter here fellas!!
Do put some CF boom supports on though. I found that I got better gyro gain with them on.
I want to put a 50 in. Can someone who know the Erog line give me the part numbers. Also, what is the gear ratio used in the Ergo 50? Venture stock is ~9.78:1 if I rember correctly.
//Payton
