Originally Posted by
ktmfrank
Thanks for the advice. power is not an issue in my case cause it will be largely overpowered in this corsair and if i encounter that problem i will go for a higher nitro percentage. one of the cool side of saito...
Make sure that you secure the flex pipes near the ends & they must not have any tension on them. They should lay in or very near the secured position before the mounts are tightened.
