RCU Forums - View Single Post - Epoxy question
Thread: Epoxy question
Old 11-26-2013 | 11:44 AM
da Rock
Yes
As already mentioned, the longer epoxy takes to cure, the longer it penetrates the wood you expect it bond or strengthen. The farther it penetrates, the greater the area/volume of the joint. The larger area strengthened, the stronger the structure.
I used to "autopsy" every crashed plane I could. You'd be amazed how easy it is to pull apart joints glued with 5-minute. 15-minute isn't half bad for strength. 30-minute seldom can be defeated. You wind up tearing away the wood near the joint.
