RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 11-27-2013 | 01:38 PM
  #1653
izzy
Originally Posted by Dave Wilshere
Izzy
Why did you cut the fuselage? The rudder servo is completely in the fin. I just mounted the extension lead socket in the fuselage top and plug in the rudder servo lead when adding/taking the fin off.
Dave
Did I understand correctly?
Maybe I mis-explained
i made a small hole for the extension lead of the rudder servo (which is in the fin) to enter the fuse.
There was no hole for the servo lead to enter the fuse ( the fuse came with 3 holes -1 tube for fin,1for bolt,1 for locating front pin)
the hole I made is located between the pin and tube for the servo extension. However there was a strip of wood under the fuse skin between the 4mm nut and tube
am I making any sense ?
this iPad cannot upload pics -
thx.
