Originally Posted by
ahicks
I'm not sure about interchangability, but I can tell you that the resistor is necessary unless you're using a resistor type plug. As the CM-6 is not a resistor plug, you'll want to install that resistor in the boot.
Correct , the standard spark plug CRRC GF26I use is CMR7H , which is a resistor type plug.
