Originally Posted by
TLH101
I have just started working on one of these. Have stripped all the stripes off and will be painting it a more desirable scheme. Will be powered with a pair of 4250 650 Kv motors on 4s. I am running this set-up on a similar sized A-26 and it's good combo. I'm pretty sure I will be replacing the tip tanks with a set of tips.
I agree about the paint scheme. I have seen some other Twin Comanche posts that have very nice paint. I may remove the stripes and do a custom paint job after I see that it flies well. I will probably make and use normal wing tips too. I already have a Cessna 310 with the slanted wing tanks which looks much better.
On your motor setup that you like what is the brand/manufacture and the Continuous/Max current rating for those motors? Also what Prop size are you running?
Don
