You will also most likely find the bearing hard to get out so the easiest way to get them out is to heat the crank case up in your oven at about 250 for about ten minutes or so and then use a wood dowel as a punch to get then out and then the same when installing new ones ok .
I did this with a saito 100 engine and it works just great .
cheers.
