RCU Forums - View Single Post - replacing bearing in a os FS 61???
Old 11-29-2013 | 07:03 AM
jaka
Hi!
A much easier way is to use a propane torch!
If the bearings don't fall out as you slam the crank against a wooden plank...just cool the crank in water and then reheat it again. Repeat this process until the bearings fall out.
This process is the same whether it is two or four-stroke Engines.
This is very easy to do!
Name:	tn_Vevhus värms upp ASP.40.JPG
ID:	1943309   Click image for larger version
Name:	tn_Nytt kullager på vevaxel ASP.40.JPG
ID:	1943310   Click image for larger version
Name:	tn_Vevaxel monteras i ASP .40.JPG
