Originally Posted by
David Gladwin
Hi Jim, Yes I am v well after Meiringen, trust you guys are too. Had a wonderful time in Switzerland, what a great event.
To take up your points:
Not really sure that you can compare the cost of the Wea receivers with the Wea because they contain lot more than the Jeti units. The programmability and extensive data down link is worth every penny (cent) to me.
A very happy thanksgiving to my American friends.
David.
Hi David,
You might have a better look at the Jeti Receivers.
ALL of them are Wirelessly programmable
ALL of them are 16 channels
ALL of the send DATA stream
ALL of them will do Satellite, Full, UDI, PPM + Servos, UDI + Servos mode
ALL of them have programmable Servo Pins
ALL of them have programmable Servo FailSafe
A very happy thanksgiving to everybody.
Zb/Jeti USA
[TABLE="width: 100%"]
[TR]
[TD="width: 240, bgcolor: white"]
[/TD]
[TD="bgcolor: white"]
Fail-Safe Setting
Switches ON/OFF of the Fail-Safe function. If the Fail-Safe function is deactivated, there is no signal generated in any Central Box outputs at the signal loss. If you activate the Fail Safe function, you can also select how the Central Box responds at signal loss for each of the individual outputs. [/TD]
[/TR]
[TR]
[/TD]
Servo Mapping
Servo No. - Assigning outputs of the transmitter to the Central Box outputs.
Group - Assigning specific output to the group of output impulses that will be generated [/TD]
[/TR]
[/TABLE]
