Unfortunately that's not the hard part for the OS FSs. The hard part is getting the wrist pin out of the back hole. It's a terrible design because you have to pull it out, but if it is stuck it is very difficult to get enough grip via the tiny hole in the pin. Only AFTER that is done do you get to pull the piston and crank and knock out the main bearing.
