RCU Forums - View Single Post - Covering
Thread: Covering
Old 11-30-2013 | 08:40 AM
gphil
Default Covering
Finished watching the vids on covering and did pick up a lot of info. I am covering a wing from a Sig trainer. The wing is basically a hershy bar type with the bottom on the tips curving up. A simple wing and a no brainer to most of you. In the videos the wing was tapered and only took the covering almost to the end. Did the tips in a separate operation. Is this normal procedure or can you take the covering for the entire length of the wing? Thanks for your time and hopefully will see responses soon. gphil
