Hello all
Picked up a roll of white tape from LHS and got it put on the fuselage really looks good.
I also was looking at the dummy engine set up and the way the cowl was cut out for the carb there’s no way I can use a cylinder head in that area. This is a wood cowl and as you can see in the picture is ¾” short for the engine. So as I see it I can
1- use only 3 cylinder heads
2- try to add ¾” to the cowl then I could fill in and make it work
3- just leave it as is
