Well, I stuck the dual tank mod on my savage ss whilst I was building it, and I've not had a single problem of that kind...
Try searching on
http://www.savage-central.com/ for "dual tank mod" - you should come up with something.
Basically, you need a 2oz (60cc) header tank and a little bit more fuel tubing. Mount the tank in the right place (you can use alloy brackets, but I just used tie wraps!) and you're set to go
Only downside is you have to prime the header tank before you start up each day (assuming it's empty). Other than that, the pros far outweigh the cons
