I would got 2 pins in front and two nylon bolts in the rear. On the LT-40 I built back in 2004 the ailerons ran the length of each wing and were connected controlled by the same servo with two short pushrods. I know yours is an earlier kit but unless the ailerons are different I see no advantage to using 2 servos. I will be watching your build good luck!
