RCU Forums - View Single Post - New Nitro Engine Revving Up and Down
Old 12-05-2013 | 07:18 PM
jester_s1
Moderator
How did you move the HSN that made it run right? Do you mean you adjusted it or do you mean you pushed on it?
To answer the bearing question, you can only eliminate other causes and then replace the bearing to see if it helps.
