RCU Forums - View Single Post - Sig 1/3 Spacewalker
Old 12-07-2013 | 07:23 AM
WacoNut's Avatar
WacoNut
Getting ready to glue and epoxy the different laminates together.
I discovered none of the laser cut parts are marked. This required a bit of time to go thru and label the parts to the diagrams supplied in the instructions. The main wing spars are laminated from 1/8x3/4" spruce stock. I am going to go thru the manual and try to locate all the laminations and get them all out of the way before I get started. Should make the build go smoother down the road.
I am using T-88 epoxy for the spar laminations. This is a very slow cure epoxy so the actual construction will not begin until tomorrow.
Later!!
Anthony
