Originally Posted by
WacoNut
Tom,
Did you install the ply bands to cover the wing joints? Just wondering how that works out? looks like it would be easy to break.
Later!!
Anthony
Anthony, I did install the ply bands. I purchased a sheet of 1/32 ply, and cut and extra set of bands. I laid down two layers of the ply strips. The first layer (bottom layer) was 1/4" narrower Than the top.
The narrow band was glued flush to the rib. The top band was glued over it, with a 1/4" overhang.. This is plenty to hide the joint, and the extra layer allows the outside wing panel to slide on easily, without snagging that thin ply strip.
I glassed the strips with 1/2 oz cloth for durability.
