RCU Forums - View Single Post - Turbines vs EDF
Thread: Turbines vs EDF
Old 12-08-2013 | 09:17 AM
Henke Torphammar's Avatar
Henke Torphammar
Originally Posted by mikes68charger
Hey guys not sure were to ask this question but I'm having 2nd thoughts on my original plan. I'm restoring a Byron F16 I just got done fiberglassing the wings ,etc moved the servos into the wing and rudder
I was going to use the byron fan with a Jet Screamer motor on 12s with a Castle 160amp ESC
well my motor showed up this weekend and the motor (not the fan etc) weighs almost 3 pounds!
and I was told I will pull around 130amps at 17pounds thrust.
But I also have an old AMT 180 pumped to 17.5 pounds sitting around,
So I know turbines have a lot of eflux but electrics are supposed to be lighter but in this case I think this heavy edf will be close to the weight of the AMT
so anyone ever convert there large EDF to turbin or the other way around?
what are your thoughts?
thanks
I've done a bunch of EDF to turbine convertions and found that you need twice the thrust from the EDF to equal a turbine. So your 5kW 12S EDF setup would give the F16 the same performance as a 8lb thrust Kolibri turbine would. Imagine how light you could get if going with a 9.5oz engine and only 28oz of fuel(!) But most would probably want more oumpf then that, even though it would equal the 12S EDF.
Looking at it the other way around your 17lb turbine would make the job of a 34lb thrust EDF setup, that would be like 10kW. Probably over kill for the airframe.
