RCU Forums - View Single Post - 14SG switch question?
Old 12-09-2013 | 08:32 AM
McXtreme
Thank you for your quick reply,
My application is that I am adding a downed aircraft buzzer switch with an on/off condition to port#2. I moved the elev channel to chan#12 and made changes in the S-bus, the Elev works fine. But the buzzer I plugged into port #2 with Aux#3 does not.
When I read the 14SG manual for switch setting on page#166 it seems to indicate that I will receive an on/off menu option when I select a switch as in my case with "SA".
So, why do I not see the on/off option and how may I complete my buzzer switch installation to port #2?
Dale
