RCU Forums - View Single Post - Have three questions on engine adjustment
Old 09-28-2003 | 08:58 PM
Jim Schwagle
Default RE: Have three questions on engine adjustment
If on throttle up the engine hesitates, puffs a cloud of smoke, then spools up, you're rich. If it hesistates on throttle up, with no big cloud of smoke, you're probably lean.
On the second engine, if it begins to speed up at idle then dies, it's lean. If it just slows down then coughs and dies, it is probably rich.
If I remember correctly, according to Clarence Lee, the high speed needle valve should be about 3/8" below the top of the tank. Half-way is too low.
