Lots of glow converted to spark. Normal glow carbs work fine, just turn in the needles a lot more. The fact the engine is small means you don't need a pump or regulator. Its the size of the engine and distance of the tank not the fuel that requires the pumper carbs. I suspect it will work but you will need some methanol and a lot of oil so there will not be much of an advantage to mixing your on glow fuel. BTW use Bakers AA or synthetic oil from Morgans, Sig, or Fox and not Klotz. Good oil for around $20 a gallon.
