RCU Forums - View Single Post - F3A Lights
Thread: F3A Lights
Old 12-12-2013 | 12:40 PM
OhD
Originally Posted by najary
The led heat sinks weigh 25 gram (12.5X2), they have to be that big because the leds get very hot and you need a lot of cooling area so they will not burn.
To avoid them from burning I cannot turn the lights on the ground more than 30 seconds.
The heat sink of the Rc Controller Power Supply unit is very small 9mm X 9mm and weighs only about 3 gram.
Best regards,
Isaac Najary
Isacc, is it possible to pulse the LEDs to reduce the power consumption and heat load? Something like 50% duty cycle at one or two Hertz?
Does the LED driver circuit reduce power automatically at a critical temperature?
Jim O
