It absolutely baffles me why someone would spend $2,000 to $3,000 on a great turbine engine (like Kingtech!) and then try to cut a corner and save a dollar or two with turbine oil other than Kingtech's oil. Why? IF you had a problem after using Kingtech oil, then Dirk and Barry would stand by you. But, as Dirk has clearly stated, other oils such as two stroke oil are BAD for their turbine! Don't do it!
Regards,
Gus
