Well the flight skin went ok for my first time. I used the gorlia glue first and found it a pain and took 4 hours to dry
and the glue would try to expand wear not fully clamed. So on the smaller parts I started useing very little foam safe ca. Works great!
With the ca parts they were about 90% ready for paint the gorlia glue parts took one very thin skim coat and a few primer coats/sandings
i put the servo in the foam rudder and in the wings
also added 1 carbon spar in each wing and wood door Robart hinges. I don't think it was need thow
so can I get a pic if were you are putting your motor compaired to CG and were you think your fuel tanks are going.
Thanks mike
