Already some very good info to you here, bossrc. All I can add, is the fact that mine ran perfectly for 60+ flights without the need for a external fuel pump. I strongly recommend that you measure the temp on each of the cylinders after every flight, to make sure you don't miss a non working cylinder. Good luck with your fantastic motor! :-)
