Not stupid Robert. Theoretically, you are correct. The amount of weight that you add should bring the control surface to the neutral position when hinged, however the weight that I have added is per the spec on the plans. These don't however get the elevators neutral, more weight is needed which I am not adding...
You're an evil man there David!
