I can make any type of tire/wheels needed. I have 1/12 pan tires available now for $20.00 plus shipping for a set of four. 1/10 scale pan car tires will be available in two weeks or less for $25.00 plus shipping for a set of four. I'm designing the molds now for 1/10 touring tires and need some input from you guys on the different designs of rims available (were the tire mounts).My tires are solid and not caps that run foam inserts. I will have tire softener s and conditioners that will let you dial your tires in to what you like. This also allows you to get a lot of use from a set by running them way down if you are just bashing around parking lots. The tires must be designed to fit the rims. If a set of my tires fit hpi wheels will that fit most other touring car rims or do they vary a lot. Would you guys like the tires to fit rims like the foam tire come on or standard hpi type rims. I'm more familiar with pan cars than touring cars so any input would be appreciated. Let me add that my tires are designed for grip and not specifically for drift but may work ok for that on certain surfaces. I think they would work very good for spec class racing and would be very economical because of there longer service life.
