RCU Forums - View Single Post - Side mounted carbie good or bad outside of the cowl?
Old 12-15-2013 | 11:13 PM
izzy-israel-73
I see you have a 2 stroke there inverted did you have any problems with it and what size motor is it? As I said in one of my other post's I had a 55ax inverted what a pig of a motor kept loading up had to clear it all the time, I had to have it running at a 3rd of the throttle just to get over on the field after fueling it, still there was a chance she load up and stall when going to take off! Tho I did get better results with a four stroke glow plug but could not get it to idle well enough and that's not a good thing when you come in to hang it off the prop and she stalls !
