RCU Forums - View Single Post - A Ringmaster Bi-Plane
Old 12-18-2013 | 05:35 PM
  #81
flyingagin's Avatar
flyingagin
I removed the aluminum tubing from the strut assembly.
Then I finished epoxying the top 4 40 rod to the carbon rods, so the strut is now glued together as a one piece unit.
I will glue some balsa to the carbon rods and sand that to shape. I have some aluminum tape on the way courtesy of a brother on the ring site. I will cover the struts with that. Stuff is strong, and shiny. BLING!!!!
I will use the aluminum tubing for the center struts sans the carbon rods. I can put some brass in it at the center and ends so it will hold the 4 40 mounting bolts.
Ken
