Just for you Vincent.
Pic # 1-Measure the header and multiply by the number of wraps plus an inch for the lines to connect to.
# 2-Anneal the brass tube, it will become real bendable. And support the wire in it's entirety or it will become two pieces.
# 3-Hold firmly to the header.
# 4-Wrap tube around header tightly.
# 5-Install and hook up smoke lines.
At final assembly the lines will get clamped and the Tee will be secured to the engine.
