RCU Forums - View Single Post - jester_s1 I need your help
Old 12-21-2013 | 12:35 PM
  #69
daddyrabbit1234
My Feedback: (14)
Originally Posted by JohnBuckner
OK had photos of four wildly different types of cowl all using the same system posted but the system here disallows all but two at a time anyway I am done with that no point for me to waste any further time.
daddyrabbit I would like to approach something else concerning your airplane that has bothered me since you posted the last photos of the J-3.
Only the cylinder head is exposed outside the cowl in the high engery air. But since you have no inlet air and very little outlet air in the covered over tunnel and the very tightly cut outlet around the exhaust at the bottom.
I beleve this will cause relitively stanant air within the cowl and even around the lower cylinder cooling fins. I think there is a good chance that you may have running problems from cronic overheating. Unless you open up that bottom cowl outlet and allow some air inlet Otherwise it just becomes an oven inside.
I think an awfull lot of the running problems some fellows go through is just simply the refusal to let those cowls breath a little more.
John
John, I'm going to open up some air vents on the front of the cowl as Larry suggested before. I'm waiting on another OS 40 LA to arrive before I proceed with the vents. I'm into scale and detail big time on everything I do so with that said I plan on somehow taking the head from the incoming 40 and mounting it on the other side of the cowl to make a true looking twin cylinder.
I've built models and dioramas for years and I think that's why I'm so detailed about anything I build. Here's a 1/25 model I built recently. Its mostly scratch built except the tub and wheels. Grannies rocking chair on the back of the truck is only 1 1/2 inches tall and it took almost a day to scratch build that rocker.
1/16 Nomad drag beater
ID:	1949802   Click image for larger version
ID:	1949803   Click image for larger version
ID:	1949804   Click image for larger version
