RE: ST G 21 dissasembly
Once the liner's removed, and the crankshaft is fully seated against the rear bearing, the connecting rod can only come off by sliding it aft, off the crankpin. Sometimes it's a bit tight, and you'll have to pry it a little bit. We use curved pliers to do the job. Others have used a large carriage bolt, putting the head of the bolt under the rod and against the crankshaft. The rod will 'pop' off.
Getting it on is much easier.
