RCU Forums - View Single Post - Engine Break in
Thread: Engine Break in
Old 12-22-2013 | 03:11 PM
shane55
Default Engine Break in
I am replacing the Cylinder, Piston and Ring on my CRRC GF26. I presume the engine needs a break in period after doing this. The CRRC GF26 manual only seems to describe the break in procedure as being using a higher oil to fuel ratio for 2 to 3 hrs run time.It does not state if the oil should be straight or synthetic Shouldn't a straight oil be used for the break in? I have a dle20 also and the break in procedure here calls for 3 to 5 gallons running on straight oil before switching to synthetic.
