that didnt work out so well ... after soaking the motor and carb in new fuel. i changed the fuel line and cleaned out the tank. once i got the engine to run I started to try and tune it but the peice that connects to the starter and the pin and the bottom of the rod cracked causing metal to go threw out the block and caused the rod to brake the case open
