One wing mostly built, need to add rib W1, cut the dihedral, and cut off the excess spar on the tip end ... mulling lessening the dihedral, and bolt-on method.
Going to get the other wing to the same state then worry about the dihedral, I'll worry the bolt-on method after I have a fuse to hold it up against.
