Originally Posted by
fisher3208
A airboat with a rudder in the water is not what a airboat is about. A airboat is designed to go over weeds and wet grass and even on the bank if your engine is powerful enough, its not ment to have a rudder in the water its supose to have air rudders.If you want a rudder in the water build a v bottem or something and you can go realy fast and turn realy sharp. If you want better control put 2 slats on the bottom of the hull about 6 inches long on each side and make the rudders the same higth as the prop to get full forse of the air over them. I have 4 air boats electric and nitro and they run fine and turn good ,better in the direction that the prop is turning but ok the outher direction too.I have a 51 inch airboat with a 140 nitro turning a 18 inch pusher 3 blade prop and it goes where ever it wants to go and runns in the 40 mph...Bob
fisher3208 Here in the real world we know what an airboat is supposed to do and be. It's important to keep safety in mind as well. These glow engines with a prop turning at rpm can cut like a razor.
