Originally Posted by
TomCrump
I think you are on the right track. The 1/4 scale Cubs are probably a bit much, when learning how to build. The Sig 1/5, and the Great Planes Cub .60 should be doable. The problem would be that I doubt the 20cc will fit in either cowl.
The 4 Star 120 may be the ideal solution. It's a larger airframe, but it contains a simplified building technique. The 20cc should power it well.
The DLE 20 with a wrap around Pitts or stock muffler will fit in the GP 60 cowl with no modifications. Room to spare!! That is a fairly large airplane. A 20 would be too large for the 1/5 SIG CUB.
