RCU Forums - View Single Post - A Ringmaster Bi-Plane
Old 12-26-2013 | 10:18 AM
  #88
flyingagin's Avatar
flyingagin
I have the bottom wing re mounted, a bit rough yet as it is still not perfectly aligned, just close. I will fix that later. And then I will add alignment tabs to insure it goes on in perfect alignment.
So here are some teasers. The stab is not yet glued in, just a press fit into the slot for it. Lots I want to do to the fuse first.
Ken
ID:	1951457   Click image for larger version
ID:	1951458   Click image for larger version
ID:	1951459   Click image for larger version
