Other than the motor mount former which should be from plywood make the others from balsa. It'll be lighter and you simply do not need the strength for those formers.'
If it were me I'd have used a couple of more flat ribs on each side of the stabilizer. Not so much for the added strength but to keep the covering from pulling the leading and trailing edges to slightly scalloped shape when the covering shrinks.
