Hi Slyskydogg,
Thank you for your patience, with us in getting your answer to you.
After checking over the manual, it was noticed that the word that you are reading "meeting" was in fact a translation error and it should have been "mixing".
So in the first paragraph of the manual, they are just letting you know that there is almost no rudder mixing required when using the GYA352.
Also the word "correction" rudder on the last page of the manual, should be "corrective" rudder, and again they are just trying to tell the consumer that with the GYA352 will correct with the rudder during a stall.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (
http://www.futaba-rc.com)
