RCU Forums - View Single Post - Tail dragger setup
Old 05-09-2002 | 05:56 PM
MinnFlyer's Avatar
MinnFlyer
Default Tail dragger setup
Good explanation Harry. Yes Bgor, towing in the wheels a few degrees will help prevent ground looping. As far as the pulling to one side, are both of your wheels turning freely? also, check to see if maybe while they are rolling, maybe one of them is being force to the inside, or outside of the Axel and rubbing on something causing it to seize up.
