I temporally mounted the engine, and the carving for the top of the tank compartment. I had to split it and relieve it for the front strut legs. I also removed the wire landing gear legs from a RC Kadet Jr, that is not being used, and mounted it to the bibe. Need to bend the legs back in as it was an over sized gear, and I had bent, and spread the legs out a lot. But I think once I bend the gear back to it's original angles it will work just fine. I have to sand the rust off it and then paint it.
Ken
