As I could remember I have one of that ESC before, to enter you need to lower the throttle stick.
Check the setting of your radio th setting, low need to be 0.
to initiate th up then plug ur battery then listen to the beep, if setting is right like the first beep (ex for reverse setting) lower your stick to enter then slide up
for the next following setting.
